CUCM and CUC 11.5(1)SU6
RbkMan
CUCM and CUC uses the same 11.5(1)SU6 file. Can I upgrade both CUCM and CUC at the same time using one file?
Jaime Valencia
Yes, it's until 12.x when CUCM and CUC have a completely separate ISO for each product.
java
if this helps, please rate
Flo.Matalis
Make sure once the upload finished, the MD5 is the same as noted on the Cisco download portal to ensure the integrity of the file.
Jaime Valencia
java
