CUCM BE migration to CUCM and UCXN stand alone
clayostlund
Contributor
Contributor
I have a customer that has purchased a new CUWL standard deployment.  They are currently running on cucm be 8.0.3.  I have loaded a new server with cucm 8.0.3, and a separate server with UCXN 8.0.3.  I'm looking for any hits or tips on the best way to migrate the business edition to the new cuwl std. Setup.  Thanks
smizerny
Beginner
Beginner
Hi Clay,
The Unified CM Business Edition Product Family Ordering Guide posted on Cisco Partner Central has a section (2.8) on Migrations that walks you through how to perform the migration you describe above.
Direct link to the OG:
http://www.cisco.com/web/partners/downloads/partner/WWChannels/technology/ipc/downloads/ordering_guide_for_cisco_unified_comms_mgr_bus_edtn_prod_famly.pdf
HTH.
Stan Mizerny
Product Marketing Mgr.
Recognize Your Peers
