CUCM Cluster "Partition Unalligned" Issue Resolution by PCD (Prime Collaboration Deployment)
mesut ozcan
Dear all,
I will test soon (asap i got bootable 9.1.2 software) to solve "partition unalligned" issue with CUCM Cluster version 9.1.2.11900-12.
In my opinion, we can solve this issue with PCD as migrate unalligned cluster to a new cluster with same version.
Do anybody test it before?
What is your opinions?
Best Regards,
Mesut
Aman Soi
Hi Mesut,
I did not understand why u want to use PCD for same version?
You can simply take backup and restore it on new VM.
regds,
aman
[+5] Aman..
mesut ozcan
Hi Aman,
As i found out, correct answer should be "migration to 9.x unsupported by CPD" for CUCM version 9.X.
But just imagine, you have 8 servers in a cluster at version 10.X with Partition Unalligned issue. Is PCD not a good alternative to DRS to solve this issue while migrating to a new cluster with PCD?
Best Regards,
Mesut
Hi Mesut,
I suggest opening TAC case since I do not have any idea wherein same CUCM version is installed using PCD.
regds,
aman
