CUCM cluster shutdown and restart
TIS Network
Hello everyone,
We have a cluster consisting of 5 CUCM servers (1 pub and 4 subs) and 2 Unity Connection servers (1pub and 1sub) that we want to upgrade to version 11.5 from current version 11.0.  What would be the correct procedure to gracefully shutdown these servers to add serial connection redirection for troubleshooting if something were to go wrong during upgrade process?
Thank you
I would recommend you to just simply do it on one server at a time, aka shut it down from CLI, do the changes to VM settings you want and then power it back on.
Response Signature
6 Replies 6
Jaime Valencia
A quick google search for: "Cisco cucm shutdown procedure" will provide all the info you need.
java
if this helps, please rate
TIS Network
Hello Jaime,
I found this when Googling - https://community.cisco.com/t5/unified-communications/procedure-to-gracefully-shutdown-and-power-up-cucm-cluster/td-p/3871034
What is uncleared to me is UCCX.  I don't think I have it so for our situation:
1.  Shutdown CUCM sub servers and Unity sub server.
2. Shutdown CUCM pub server and Unity pub server.
Powering up is the reverse.  Can you please confirm I have it correct?
AFAIK you need to shut down and bring it back based on the CTI id on sequence. you can find the CTI ID on Cisco Unified CMs. make sure the DB replication shows 2 once they are back.
Response Signature
Response Signature
Thank you everyone for replying.  I'll go with Roger's recommendation.
Xiaoyao_998
Shut Down or Restart the System
Use this procedure if you need to shut down or restart your system, for example, after you make a configuration change.
Before you begin
If the server is forced to shutdown and restart from your virtual machine, the file system may become corrupted. Avoid a forced shutdown; instead, wait for the server to shutdown properly after this procedure or after you run utils system shutdown from the CLI.
Note
If you force shutdown or restart the virtual machine from VMware administration tools (vCenter or Embedded Host Client):
Procedure
Step 1
From Cisco Unified OS Administration, choose Settings > Version.
Step 2
Perform one of the following actions:
  • Click Shutdown to stop all processes and shut down the system.
  • Click Restart to stop all processes and restart the system.
