CUCM Connectivity with CUAC
mohammad saeed
Level 5
Level 5
Hi Guys,
I have CUCM and CUAC the first time I made the test connectivity was successful but when I clicked on save gave me this message: connection connection test failed. Please check the connection details and try again. Error Data : CONNECTION_ERROR
and I couldn't make synchronization with CUCM!! I restarted both but no answer!!!
any help please!
Mohammad Saeed
10 Replies 10
Jaime Valencia
You need to mention if this is CUACS, or CUACA, and versions.
java
if this helps, please rate
Thanks Jaime
Between CUCM 8.6 and CUACS 9.1 the first installation every thing were good and the synchronization was working, but suddenly I clicked on save button then this message appeared and lost the connection.
That info cannot be correct, CUACS only exists on 10.x+ versions.
You'd probably want to go and see exactly what you're using, and check the TSP config is OK and working.
java
it's Cisco Unified Attendant console Administrator business edition 9.1. Where can I found TSP config?!
Are you installing this for the first time?? or was this already working???
java
I installed it and and start test connectivity with CUCM and was working good except I couldn't synchronize the CUCM Director numbers then I couldn't login with Attendant console client after that I got problem with CUCM connectivity!
I checked TSP config and it's OK no problem about it! any Idea, please!
I reinstalled the CUACA in my 2008 server and I got the synchronization again with CUCM connectivity but during activate the Directory synch I lost the CUCM synch !
What is the problem here! please any Idea
mohammad saeed
Level 5
Level 5
Any help from any one please!
If you're in need of urgent help I'd probably suggest you to call TAC
java
