01-28-2016 07:41 AM - edited 03-19-2019 10:40 AM
Hi Guys,
I have CUCM and CUAC the first time I made the test connectivity was successful but when I clicked on save gave me this message: connection connection test failed. Please check the connection details and try again. Error Data : CONNECTION_ERROR
and I couldn't make synchronization with CUCM!! I restarted both but no answer!!!
any help please!
Mohammad Saeed
01-28-2016 08:38 AM
You need to mention if this is CUACS, or CUACA, and versions.
01-28-2016 09:26 AM
Thanks Jaime
Between CUCM 8.6 and CUACS 9.1 the first installation every thing were good and the synchronization was working, but suddenly I clicked on save button then this message appeared and lost the connection.
01-28-2016 09:29 AM
That info cannot be correct, CUACS only exists on 10.x+ versions.
You'd probably want to go and see exactly what you're using, and check the TSP config is OK and working.
01-28-2016 09:34 AM
it's Cisco Unified Attendant console Administrator business edition 9.1. Where can I found TSP config?!
01-28-2016 09:44 AM
Are you installing this for the first time?? or was this already working???
01-28-2016 09:49 AM
I installed it and and start test connectivity with CUCM and was working good except I couldn't synchronize the CUCM Director numbers then I couldn't login with Attendant console client after that I got problem with CUCM connectivity!
01-28-2016 10:18 AM
I checked TSP config and it's OK no problem about it! any Idea, please!
01-28-2016 12:26 PM
I reinstalled the CUACA in my 2008 server and I got the synchronization again with CUCM connectivity but during activate the Directory synch I lost the CUCM synch !
What is the problem here! please any Idea
01-29-2016 12:04 AM
Any help from any one please!
01-29-2016 06:50 AM
If you're in need of urgent help I'd probably suggest you to call TAC
