I am interested in others strategy in migrations from CUCM/CUPS 8.x to 10.x, and UCXN 8 to 10.x. (P2V for all)
I am thinking of using PCD to migrate the CUCM/IM&P and change hostname/IP Addresses for a staged migration to bring them up in parallel prior to cutover. Has any one else done this, and considered how existing Jabber/CUPC users are affected? E.g If I want to migrate users in stages, how do I perform the necessary DNS changes so that only subsets of users are affected at a time? (Eg. Site by Site)
For UCXN, seeing as PCD is not yet supported, I was thinking of building a new UCXN cluster from fresh (instead of the usual DRS backup & restore) and then using COBRAS to migrate the data on the cutover day. If I do DRS method, I need to build up the lab with the different IP Addressing so it seems much cleaner building from scratch...Has any one else also gone down this path?
Basically I need to have as minimal impact to the users as possible. Any one else's thoughts or strategies would be much appreciated!
