CUCM Integration with PMS(MICROS)
Hi Everyone,
We are in the process of integration CUCM 8.5 with property management system (MICROS).  Are there any guides provided on integrating CUCM with PMS. If so please share. We cannot use any third party applications.
Thank you.
Jaime Valencia
We do not test 3rd party apps integrations for the most part, you would need to reach MICROS and see if they tested and certified their product for CUCM integration, and how to do so.
java
if this helps, please rate
Thanks for the information Jaime.. Will reach MICROS.
