CUEAC 8.6.1.9, CUCCX 8.5.1 and CUCM10.X
Laurel McDargh
We are determining our upgrade paths for moving to CUCM 10.5.2.
If we upgrade to CUCM 10.5.2, will CUEAC 8.6.1.9 and Cisco UCCX 8.5.1 still work?
Jaime Valencia
No, compatibility information is contained within the CUEAC install and configuration guide, and you can review the UCCX compatibility guide for valid options, you can find it all on cisco.com
In 10.x you only have standard and advanced AC, I suggest you review the documentation on both to determine which one you require, info is in the same AC documentation page where CUxAC docs are.
java
if this helps, please rate
Hi Laurel,
you can refer the link
http://tools.cisco.com/ITDIT/vtgsca/VTGServlet
regds,
aman
