CUMA 7.1.3 and Blackberry Bold 9000
bluejays
Beginner
Beginner
I am working on a project where I need to deploy CUMA 7.1.3 and integrate that with Blackberry devices. According to Release Note of Blackberry Client 3.1.12, Blackberry Bold 9000 is a supported model. However, I am not able to select that from the handset platform management page.
Can someone please confirm if Blackberry Bold is supported?
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
I just looked and it's supported, you should be able to choose any model and should work fine on the 9000 model.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Indeed, I too have found this to be the case.
Mark
I uploaded the client 3.1.12 to BES(4.1.6) and the BES said (under the Software deployment policy) the device is not supported. And I don't have the client icon on the phone.
I will wait for another couple hours to see if the BES pushes the client.
Recognize Your Peers
