03-05-2010 06:24 AM - edited 03-19-2019 12:34 AM
I am struggling with getting Desk phone working. I have done everything that is recommended except for changing the Ldap port on the CCM. I have changed the port on the CUPS to the global catalog. I have restarted the CTI Manager on all CCM's and I have changed the CTI Timer to 300 and restarted the services again. I have done my best to verify that the user/phone is allowed for CTI access. I can use the click to dial application without issue so I would expect the phone and user to be configured correctly. Soft phone controll works with out issue. After changing to timer I do see (on occasion) the Server Health respond that Desk Phone (CTI) is working and it has my device listed...but when I attempt to change to that device I go into disabled immediately. If the solution is to change the CCM Ldap port what issue could that cause for my CCM users/directory listings?
TIA,
Joe
Solved! Go to Solution.
03-10-2010 06:28 AM
Yes, I understand about the GC port and LDAP. I have a web server that has the images and I have pointed the Presence Service Paramter
to it with %%uid%%. I can see the image in the CUCS Presence viewer but it doesn't show up in the CUPC.
Joe
03-10-2010 07:04 AM
Hmmm
If you are using AD, shouldn't you be using sAMAccountName for substitution field though? In my AD, uid is blank...
Obviously I'm assuming you're using sAMAccountName to name your pictures...
http://webserver/%%sAMAccountName%%.jpg
Aaron
03-10-2010 08:39 AM
I am using AD and it appears to be working fine...what I am confused about is I see the image of the user in the Presence viewer on the
CUP Server. That tells me that the image and the users are working together. My question is how the client pulls these images? I get the default blank image when I attempt to call someone that has an image. I don't see their image in the contact details either under cupc.
Joe
03-10-2010 08:45 AM
Hi Joe
Well - all I can tell you is that if I set my photo attribute to http://x.x.x.x/%%uid%%.jpeg, CUPC doesn't request anything.
If I set it to sAMAccountName, it requests jpegs for each of the people in my contact list at startup.
I can only presume that CUPS server itself is doing something a little more intelligent...
Have a look at your uid property in AD, if it's blank, then why use it?
It's in the manual:
You can configure a parameterized URL in the Photo field in the LDAP attribute map in Cisco Unified Presence Administration so that Cisco Unified Personal Communicator can fetch pictures from a web server instead of from the LDAP server.
Before You Begin
•Use %%uid%% as the substitution string.
You can use any LDAP attribute whose query value contains a piece of data that uniquely identifies the photo of the user. For example:
–http://wwwin.cisco.com/photo/std/%%uid%%.jpg
–http://wwwin.cisco.com/photo/std/%%sAMAccountName%%.jpg (for ActiveDirectory)
•The double percent symbols are required, and they must enclose the name of the LDAP attribute to substitute.
Aaron
Please rate helpful posts...
03-10-2010 09:31 AM
Again this was an oversite on my part..I was edited the Presence Server Parameter, no the LDAP attribute. I think everyone for you help and I have rated the posts.
Joe
03-10-2010 09:35 AM
Good to hear it's all working.
Aaron
06-28-2012 08:39 AM
Hi there,
I have a similar issue with CUPS 8.6 and Deskphone mode usage for Jabber, I cant use my Deksphone as action takes too long and fails.
The debugs I have show directory authentication failure:
2012-06-28 13:13:56,961 WARN [0x00001148] [src\deskphoneprovider\phonelog.cpp(38)] [csf.ecc] [prepareFor2GLogger] - ProviderOpen failed: reason: 0x8ccc0060, Directory login failed - authentication failed.
We are using AD LDS with CUCM with SSL Port 636.
How would be the best way to change this to work and which services would need to be restarted on CUCM and CUPS?
