CUPS 7.0.2 Problems
DOUG DAVIDSON
Level 5
Level 5
Has anyone upgraded to CUPS 7.0.2? If so are you experiencing any problems?
DOUG DAVIDSON
Level 5
Level 5
The major problems I was having with 7.0.2 have been resolved.
The problem was related to the node name on the server. It must be the host name only and not either the ip address or host and domain name.
However, it has cause one minor problem, now when CUPC connects it does not retain the domain name for the logon server.
Just an fyi, to hopefully help someone else from running into the same problems and frustrations I have run into.
Doug
This is the bug for this problem:
CSCsu88195
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsu88195&from=summary
This caused me two issues:
1. CUPC 7.0 clients could not manually update their status.
2. I was unable to "assign" unassigned users to a node server.
Jim
