CUPS integration with WebEx and Tandberg
ATIF TANVEER
Hi Everyone,
We need to integrate conference solution with CUPS 8.5. We have WebEx and Tandberg. But in CUPS the only available option is meetingplace for  video conference system even in 8.6. Has anyone done the CUPS integration with WebEx and tandberg. and is it really possible ? Appriciate your response
Atif Tanveer
No you cannot you need MP in the mix as per my understanding.
https://communities.cisco.com/message/32877#32877
Connect(for PC) and Jabber(for Mac) on the other hand can provide escalation to WebEx directly without MP
Srini
7 Replies 7
skilambi
Meeting Place is just the audio portion. It too uses WebEx, so CUPC can escalate to web conferencing using either Type 1 or 2 configuration
http://www.cisco.com/en/US/docs/voice_ip_comm/cups/8_0/english/install_upgrade/deployment/guide/dgappendixB.html#wp1099846
Also CUPC can dial Tandberg end points, if you have them registered to CUCM (like E20) or to VCS over a SIP trunk as an example until more endpoints natively register in 8.6
Srini
Thanks Sirini,
Just more clarification. doest it means that I will just provide the WebEx(SaaS) information in CUPS  for WebConferene? Like!
Conference Server: abc.web.com
port Number: 443
Protocol: https
With these configuration CUPC 8.5 would be able to start meeting ?
Atif
It should be the conferencing server address. Check the link I posted for the steps in the previous post and this one
http://docwiki.cisco.com/wiki/Cisco_Unified_MeetingPlace_Release_8.0_--_Integrating_Cisco_Unified_MeetingPlace_with_Cisco_Unified_Personal_Communicator
Srini
Hi Srini,
I am still confused. I dont have meetingplace and these all documentations are about MP. I have only WebEx(SaaS)
Atif
Hi Shrini,
I was doing some investigation on the design and what you said about conference server! pleae correct me if I am wrong
1) I shoud have Meetingplace Application server
2) I shoule have Cisco WebEx Node for MCS
Atif
IS it possible to intergrate webex with CUPC without meeting place server.? Can you please help me the steps for this.
SS
Srini
