10-12-2012 03:58 AM - edited 03-19-2019 05:42 AM
I want to create a group of phones that have custom ringtones, but not allow the rest of the phones in the estate access to them.
I have created the .raw files and uploaded them and created a Ringlist2.xml which specifies these new ringtones.
The thing I can't work out is how to allow a group of phones to download the new Ringllist2.xml instead of the default one.
Can anyone help?
Thanks for reading.
10-12-2012 04:13 AM
Hi Charles
Unfortunately this isn't supported. You can only have a single RingList.xml file which all phones point to / use.
HTH. Barry
Barry Hesk
Intrinsic Network Solutions
10-12-2012 05:30 AM
How about specifying a different tftp server for certain phones - is that possible?
10-12-2012 05:35 AM
Yes. That would work.
Point option 150 in your DHCP server scope for the phones in question to a different TFTP server which contains the altered RingList.xml file.
HTH.
Barry Hesk
10-12-2012 06:05 AM
yes of course!
Is there a way I can mass tftp all the files off the server in one go? Or, how can I find out which files I need for a 7942?
