Destination pattern range !
Jonn cos
Level 4
Level 4
Hi all experts.
When i want to simulate PSTN cloud in my lab, i usually do it using FXS port (plugging a normal analog phone). And then assigning, lets say my country's mobile codes via destination pattern, so that, from my ip phone, whenever i dial 0345xxxxxxx, 0321xxxxxxx, that analog phone rings. So far so good.
I just want to know, is the same thing possible with an ip phone. Lets say i have an IPC. I want to assign the following complete range to it
0345xxxxxxx
So that, when ever some one dials 03452101111 or 03453561234 etc, that IPC should ring. Is it possible ?
kking2008
You could certainly have a Translation pattern of that 0345xxxxxxx pattern direct to your Phone DN.  It would translate for that whole range with exceptions for direct matches, is that sufficient?
Sir, can you give me an example ? how can i use translation rule of 0345xxxxxx to point to my IPC ?
