Does CUCM and IMP "direct standard" need a serial port for dumping of installation file?
BenBen
At the end of the the "Adding and Remove serial port" instruction:
https://community.cisco.com/t5/collaboration-voice-and-video/dumping-cucm-fresh-install-logs-virtualization/tac-p/4427655#M10052
It states "There is no other use of the serial port in a Unified CM VM other than dumping the install logs, so you will not need it again unless you do a fresh install."
Does this indicate that a "direct standard" install do NOT need a serial port?
Creating this serial port would need to shutdown the VMs which is not a small task. I am performing a "Direct Standard" upgrade so I want to know if I need the serial port or not.
Much thanks.
-Ben
You would not need a serial port for what you ask about.
Response Signature
Response Signature
