E1 slip
korbenda11as
Beginner
Beginner
E1 0/0/0 is up.
Applique type is Channelized E1 - balanced
Description: DOD to International with PRI link
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20071009, FPGA: 20, spm_count = 0
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (519 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
171 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
171 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 0 Path Code Violations,
28557 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
28557 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
I can see a 171 slips error. is this ok? if not, how to fix this, whats the cause of this? thanks
korbenda11as
Beginner
Beginner
basically, with my E1 module I have two ports connected to different Telco, can this contribute to "slip" error? any suggestions?
paolo bevilacqua
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
First of all, you need the network-clock-participate wic 0 and networkc-clock-select commands.
Then check again and let us know.
