Error registering a Cisco 2811 Gateway with a clustered CallManager 4.3
joguevil2008
Hello, i'm having problems registering a Cisco 2811 Gateway with a VWIC2-1MFT-E1 interface card with Cisco CallManager 4.3.
The error displayed when debugging mgcp is the following:
//-1/xxxxxxxxxxxx/MGCP/mgcp_mp_get_not_entity(828):[lvl=2]
Invalid parameter (pkt 0x4708C5E8 pkt->mgcp_parm_lines 0x00000000)
I configured mgcp by the following:
mgcp
mgcp call-agent VOIPSVR1 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp restart-delay 300
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp validate call-agent source-ipaddr
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer voice 100 pots
service mgcpapp
direct-inward-dial
port 0/0/0:15
Previously, the gateway downloaded xml config files from the Cisco CallManager without problems and, in addition, when trying to add a Route Group (in the CallManager) this Gateway does not appear
in the list of Available Devices although
I have added it through the Device->Gateway Menu.
Need some advice and help. Thank you in advance.
20 Replies 20
I'm having the same problem as you: tried to install a VWIC2-1MFT-E1 in a 2811 on CallManager 4.3(2) via MGCP. I can add the GW in CCM, but if I want to configure the endpoints, Internet Explorer is giving "Error on page" when selecting a device pool, so I can't activate it. I tried to configure the module in other slots, without success. Also tried to configure it on a 2851, also without success. It's only possible to configure the VWIC2-1MFT-E1/T1 as a T1 on CCM on a 2811 MGCP GW, but need E1. Opened a case for this, but for the moment I don't have it running. If it's not working, I have to switch to H.323, except if you got it finally up and running as MGCP.
Greets,
David
Hi! Did you solved you problem? I have a same problem, but don't have a smartnet - I can't open case, but it is a 100% CCM bug!
No, I didn't get it running in MGCP, so I switched to H323 instead.
Can you tell me the number of SR? I try to find out what happend with your case.
Here it is: 608673541
canowlin
I bet if you add the ip name server command in the GTWY's and the CCM in DNS your issue will go away. The GTWY is trying to resolve the name. I had the same issues added the name server commands problem solved.
