Failure to upgrade Cisco Unity Connection 8.6.2 to 9.1.2
Claudio Costa
Hi everybody.
Has someone that can help me with follow problem?
I making a Cisco Unity Connection upgrade from version: 8.6.2.20000-76 to 9.1.2.10000-28. But unfortunately we can't sucessfull to make this process.
On the finish of this process, I can see this outup error:
11/23/2013 12:28:55 upgrade_manager.sh|Cleanup exiting - Cached Data: [Vendor= VMware, Inc.
HWModel=VMware
CPUCount=2
CPUType= Intel(R) Xeon(R) CPU E5-2643 0 @ 3.30GHz
CPUSpeed=3300
MEMSize=6144
BIOSVer=PhoenixTechnologiesLTD 6.00 06/22/2012
ObjectId=1.3.6.1.4.1.9.1.1348
OSVersion=UCOS 5.0.0.0-2
SerialNumber= VMware-56 4d e0 4f 4d 85 87 7b-eb 22 0e 52 a7 73 1a 22
VendorOID=1.3.6.1.4.1.674]|<LVL::Info>
11/23/2013 12:28:55 upgrade_install.sh|Cleaning up download...|<LVL::Info>
11/23/2013 12:28:55 upgrade_install.sh|Cleanup upgrade source area.|<LVL::Info>
11/23/2013 12:28:55 upgrade_install.sh|Ejecting DVD (/dev/sda1)|<LVL::Debug>
11/23/2013 12:28:55 upgrade_install.sh|Removing /common/download/9.1.2.10000-28|<LVL::Info>
11/23/2013 12:28:55 upgrade_install.sh|Started auditd...|<LVL::Info>
11/23/2013 12:28:56 upgrade_install.sh|Started setroubleshoot...|<LVL::Info>
11/23/2013 12:28:56 upgrade_install.sh|Changed selinux mode to enforcing|<LVL::Info>
11/23/2013 12:28:56 upgrade_install.sh|Cleaning up rpm_archive...|<LVL::Info>
11/23/2013 12:28:56 upgrade_install.sh|Removing /common/rpm-archive/9.1.2.10000-28|<LVL::Info>
11/23/2013 12:29:00 upgrade_install.sh|IOWAIT monitor stopped|<LVL::Info>
11/23/2013 12:29:00 upgrade_install.sh|File:/usr/local/bin/base_scripts/upgrade_install.sh:599, Function: main(), Upgrade Failed -- (1)|<LVL::Error>
11/23/2013 12:29:00 upgrade_install.sh|set_upgrade_result: set to 1|<LVL::Debug>
11/23/2013 12:29:00 upgrade_install.sh|is_upgrade_lock_available: Upgrade lock is not available.|<LVL::Debug>
11/23/2013 12:29:00 upgrade_install.sh|is_upgrade_in_progress: Already locked by this process (pid: 14477).|<LVL::Debug>
11/23/2013 12:29:00 upgrade_install.sh|release_upgrade_lock: Releasing lock (pid: 14477)|<LVL::Debug>
Best Regards,
Claudio Costa
A mensagem foi editada por: Claudio Costa
Manish Gogna
Hi Claudio,
Please perform a cluster wide reboot of the Unity connection servers before attempting the upgrade. Let us know if it helps.
Manish
Manish Gogna
Hi Claudio,
Manish
Tks Manish, I just perform a restart on the both nodes on my CUC cluster and after that I did can install this upgrade patch.
Also is very important install the upgrade patch on all servers of the cluster before perform a switch-version on the publisher and then on the others nodes.
Best Regards,
Claudio Costa
Hi Claudio,
Glad to know that it worked. Yes, you are right, we should first install the upgrade patch on all the servers and then perform a switch version on all nodes begining with the Publisher.
Manish
