Forward All Calls to Long Distance Cell Number not Working
Lt.Slothrop
I want to able to forward our help desk number to a personal cell phone depending on who is on call for that week. It works when I put a local number in the destination field for "Forward All" under the "Directory Number", but when I use a long distance cell number it fails.
I have tried changing to a CSS that doesn't have the "Client Matter Code" enabled and it still fails.
The unfortunate part is the person that original implemented this system no longer works for this company and did very little documentation.
Any guidance as to what I should look at next would be great!
7 Replies 7
Jaime Valencia
You would need to look at your route patterns and dial plan to determine if you can dial long distance with your CSS, or if you need to adjust your CSS, create a route pattern, etc.
java
if this helps, please rate
Let me ask the obvious questions first:
The CSS you configured for "Forward All" has access to a route pattern that matches long-distance dialing without a CMC, yes?
And the number you entered into the "Destination" field matches that route pattern?
If both of those are a yes, try a test where you configure the line itself with the CSS you are trying to use for CFA and dial the number for your Destination using the phone. Does it work?
Also, what is the "CFA CSS Activation Policy" setting in the CallManager Service parameters?
I apologize it has taken so long to respond but I am only part time currently.
I have followed the instructions of Cisco Rath, which would answer yes to your questions and all I get is
"You have reached a number that has been disconnected or incorrect..." message. But the destination number matches the Route Pattern.
To answer your last question about "CFA CSS Activation Policy", it is set to "With Configured CSS".
Ratheesh Kumar
Hi there
The easy way to test this is
  1. Create a new PT
  2. Create a new CSS and include the above created PT
  3. Create a Route Pattern with the cell number and point to your PSTN RouteList
  4. Configure your CallFWd All with this CSS
Observe what happens. Also check the DNA in Serviceability
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
I have followed the I followed your instructions and all I get is "You have reached a number that has been disconnected or incorrect..." message. But the destination number matches the Route Pattern.
That sounds like a message from the telco, not from CUCM, you can confirm by looking at debugs in your GW and see if the call connects. If it does, then your configuration is OK (at least to send the call towards the PSTN), you'd need to ask your telco (if you use PRI) if they expect a certain combo of settings to accept the call, or if it's just a problem with that specific number you're dialing to.
java
Hi there
It would be better if you could share the debugs from the gateway.
Just a thought, Grab a free internal number (which is a DID). Forward the Help desk to that number. Then forward the new DID number to the cellphone using a Translation pattern. Also cross check the External Phone Number Mask of the extensions as well.
Hope this helps!
Cheers
Rath!
