FXS ring group in a VG350
KJ7BZC
I am configuring a VG350 voice gateway connected to Asterisk over SIP, and was wondering if there is any way to do a ring group in the gateway itself. I am used to using hunt-group in routers, however this is not an option in the gateway and I cannot easily do it within Asterisk. I simply need calls to one dial-peer distributed across a group of FXS ports, just like a sequential hunt-group would.
Thank you,
Keith
There are hunt group features in CME, but I don't recall if the VG350 will run CME. Also there would be a licensing component to that.
I see, unfortunately it doesn't have CME on it. I was however able to get a ring group by adding each FXS to a trunk group along with the dial-peer.
Keith
