H 323 GATEWAY WITH 2 E1 trunk is not showing correct caller ID
csco11198172
Hi All,
Kindly help me to fix the issue.
H323 gateway with 2 E1 trunk with different DID ranges are displaying wrong caller ID .
All ports of H323 GATEWAY is chooses for calls and that too the channel selection is circular.
The outbound calls going through Primary PRI is showing correct caller ID irrespective of  the DID ranges mapped to them.
Need assistance to isolate the issue.
Config attached.
Ip address are changed some config which i think does not make issues i removed.
Kindly assist.
csco11198172
Hi All,
The outbound calls are taking dial-peer 12 ,with wrong caller id display.
I can see so many dial peers to pots can anyone help me in understanding the same & fix the caller id issue.
Shinaj.cm
Hi All,
The dial-peer voice 12 pots is used for outbound calls with DID range 63125XXX
But the issue is that the same DID is taking the other pri 0/0/0 also to make outbound calls and the calls are displaying wrong Caller ID . Kindly suggest a dial-peer for me to make outbound calls to the same port 0/0/1 to make correct Caller ID.
Shinaj
