Help with hybrid deployment
hwalia282
I have a customer that currently has CUCM/CUC in the cloud (ie HCS) and jabber in the cloud (ie Webex Messenger).  Customer only wants to move CUCM/CUC on-prem and keep jabber in the cloud.
Question:  is there any special config needed for jabber to work in this deployment?
Adarsh Chauhan
Level 3
Level 3
This would be a jabber hybrid model.
I guess my question would be what all jabber services would the user be provided with.
You should read about Mobile and Remote Access (MRA) which would require expressway-C and E to let the jabber make vpnless connection the cucm on prem.
Please rate and mark correct if helpful
Adarsh Chauhan
Adarsh Chauhan
