04-07-2012 12:46 PM - edited 03-19-2019 04:42 AM
One of my customer has BMS fom Honeywell. He needs to integrate this system with Cisco IPT 8.6.
IP telephony system shall be capable of providing a software adjustable temperature setpoint at each telephony terminal, this point info shall be synchronized with the BMS in order to provide the telephony user the ability to adjust the room temperature setpoint from the telephony set, or from the room wall module, and the final value of the point shall be determined as of the final order received from one of the two destinations.
The link between the two systems, BMS and IP Telephony, shall be in one of the below methods:
How can the above be achieved? What components do i require to achieve the above functionality?
Appreciate your help.
04-07-2012 06:18 PM
I am providing you with the below CUCM interop link, where in different product inetrop testing is done with CUCM and is supported.
Please see any of the similiar protocol is used with some other product which is listed here.
Hope it helps.
Anand
Please rate helpful posts !!
04-07-2012 10:47 PM
Nomykhan,
Such deployment/integration is achieved using Cisco's S+CC solution. As this is a fairly new solution ( launched couple of years ago ), the authentic place to get more assistance for both presales & postsales, is your Cisco SE ( Sales Engineer ) team. Please reach out to Cisco Sales team locally in your country for further details.
GP.
Pls rate helpful posts by clicking on stars below the post !!
04-08-2012 12:52 AM
This is what you need
