How can I add more than 9 alternate extension under voicemail user?
Bahlul Guliyev
Hello all,
I have an issue about adding more than 9 alternate extension under one voicemail user. I now that, I can add up to 19 alternate extensions (9 Administrator Defined Alternate Extension, 10 User defined). But to add User Defined alternate extensions?
Best Regards
Bahlul
Deepak Rawat
You will need to adjust Class of Service in order to allow this, refer below:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/8x/user_mac/guide/8xcucmacx/8xcucmac050.html#wpxref90793
More details can be found at below good thread by Rob
https://supportforums.cisco.com/discussion/11458251/maximum-alternate-extensions
Deepak
Hello Deepak,
I did the changes under Voicemail User COS. Only I want to know, under which user I must login and configure Alternate extension?
Best Regards
Bahlul
I found it. I must login to PCA to add user defined alternate extensions.
http://<CUC IP>/ciscopca
Best Regards
Bahlul
