How does the CDR CdrLogCallsWithZeroDurationFlag set to true affects the CPU or memory utilization?
adolfocgx
Hi, Im trying to find how the CdrLogCallsWithZeroDurationFlag set to true affects the CPU & memory but I was not able to find any information, I found some info about enabling the CDR/CMR cpu behavior but not the CdrLogCallsWithZeroDurationFlag , does anyone have a clue?
jonathan.salter
Level 3
Level 3
It's a difficult stat to track as it would really depend on your call volume.
May I ask why you are looking to do that?
Please remember to rate useful posts, click on the stars below.
I want to monitor some devices for Qos and other parameters with Vyopta software and the CdrLogCallsWithZeroDurationFlag is required to be active, but as far as I know this will logg al calls including Extension to Extension so I need to be sure about the CPU memory and disk behavior before enable it.
