How many voicemail ports come with CUWL
Kris Garner
I'm being told that the voicemail ports are maxed with CUWL licensing (144 per server).  Or, does CUWL automagically add the number of voicemail ports one needs baed on the number of users ordered?  Or is neither true?
Kris.
Aaron Harrison
Hi Kris
The last CUWL project I did got me a license for 3000+ users, and that granted 500 ports.
The actual built server supported less (I don't recall exactly) so it looks like they give you licenses for 500 and the actual count you get is based on your server or VM spec.
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Correct, the port licenses are free with CUWL and you can ask for as many ports as you desire, make sure you follow the design guidelines as supported number of ports depends on server and codec being used.
HTH,
Chris
