How to bulk remove Unity Bridge settings in 4.05?
jhatfield
I have a customer who at one time had a unity bridge integrated into an Octel. When they migrated off the Octel, they did not follow the uninstall procedure and just got rid of the bridge.
I now have 2700+ users who still have a legacy mailbox id and bridge node which I can't remove in bulk. I'm upgrading from 4.05VM with failover to 4.2VM with failover and then to a new set of server hardware this weekend.
I'm wondering if DiRT is going to give me a problem when I restore the DB to a server which has never had a bridge integration.
It looks like there are only two fields in the unitydb, can I just remove the NodeID and legacymailboxid in bulk via SQL?
TIA
lindborg
As noted on an earlier thread, DiRT is not going to have a problem with this and neither will the upgrade. Removing these values is not necessary for any reason other than ascetic. If you want to remove them in bulk anyway you will have to do it directly in SQL - this is not TAC or BU supported so make a backup first.
You can pop open QueryBuilder (if you have SQL enterprise installed) or use the query builder built into the Data Link Explorer found in the tools depot ? you can this query:
UPDATE subscriber
SET LegacyMailbox=null, RemoteNodeID=null
WHERE SubscriberType IN (1,3)
That will wipe out all those fields for full subscribers in your system.
lindborg
UPDATE subscriber
As always, Thanks for the guidance here.
