How to calculate DSP
Amit Singh2000
Hello Guys
    My company is using CMM modules in a 6509 switch as the MGCP gateways.. Some of these modules even have 9 pri lines attached . They are also providing media resources like Conference bridges and Transxocder..
Now we are planning to get it upgraded to 39XX routers with PVDM3.. How do i check that how many PVDM resources i have on the CMM module so that i can order equivlant number of PVDM3 for 39XX routers...
Thanks for your help in advance ..
Amit
Priyadarshini B.T
hi,
Here is the link to the DSP calculator, where you can calculate the amount of DSP'S you require to configure,
http://www.cisco.com/web/applicat/dsprecal/dsp_calc.html
Below is the link which will give you complete details about PVDM's
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/media.html#wp1046610
hope this helps
