How to enable voice recording for a CUCM ver 4.1(3)
5 Replies 5
whamblin
For 4.1(3), you are pretty much dependant on using a 3rd party recording vendor and doing port spanning.
CUCM has made significat impovement with media forking from the phone to enable recording over CUCM Versions 6.x and 7.x.
I can not at this time migrate, there are any 3rd party recording vendor who has been tested for this version?
Olga G.
You can find Cisco Certified partners from the Cisco Developer Network site: http://developer.cisco.com/web/cdc/home
Do a partner search: http://developer.cisco.com/web/partner/search
I did a quick search against all cucm versions and found this.
http://developer.cisco.com/web/partner/search?technologyIds=a0G40000000xlnlEAA&subTechnologyIds=a0K40000000eHsEEAU&technologyProductIds=a0I40000000ycykEAA&partnerProductFamilies=Recording (Contact Center and Unified Communications)&certified=All&onCiscoPriceList=All&portfolioPartner=All
By the way, it is time to start planning your release.  You realize you are on a release that is past end of support.  You have left yourself in a vunerable position.
Excellent responses, in full agreement regarding the update of version
Olga Galindo
