How to modify contact header on a SIP INVITE at CUBE
Hi all
I have an INVITE coming from CUCM leg at CUBE and then it goes through SP leg being modiied by Sip protocol default's behavior.
CUCM -> CUBE -> SP
The INVITE from the CUCM:
Contact: <sip:490043@23.13.0.251:5060;transport=tcp>;video;audio;isFocus;x-cisco-tip;x-cisco-multiple-screen=3
INVITE sent to provider:
Contact: <sip:490043@192.145.71.XX:5060;transport=tcp>;x-cisco-tip;
I need copy "x-cisco-multiple-screen=3" from CUCM contact header INVITE and paste on INVITE sent to provider.
I have raised a TAC case for this but no success so far.
This is done in order to overcome a SIP limitation that does not allow use the 3 screens that Cisco Telepresence Endpoint has. The protocol is TIP (Telepresence Interoperability Protocol)
does anyone has faced this situation before?
Mohammed Khan
Hi Jonas,
Check below link
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-border-element/105624-cube-sip-normalization.html#modify
HTH,
Mohammed Noor
