How to retrieve PAKs from Voice servers
Hello, we need to retrieve all the PAKs for the licenses associated to a couple MCS servers. Those are voice servers. We need that info in order to add a UCSS to the applications for a migration.
If there is a way to get that information via the CUCM server, please let us know.
Jaime Valencia
No, those only mean something when you're ordering, the voice apps know absolutely nothing of PAKs.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
Ok Java, thanks!
ryankaplan
Level 4
Level 4
If you view the license files in cucm. You can occasionally view PAK IDs
Sent from Cisco Technical Support Android App
