06-22-2011 09:24 PM - last edited on 03-25-2019 09:41 PM by ciscomoderator
Dear Sir !
I config the IPT diagram with info :
User ( Using Softphone SCCP and SIP- 10.0.16.90) ---> Call manager (192.168.16.2) <---H323-----> Voice Gateway - cisco Router 2800 ( 192.168.1.10) --> Customer
I meet one problem:
if user using softphone with protocol SIP ---- Traffic ok, ring and call reback, but if User using softphone with protocol SCCP ---> 1 way, i can listen on phone from Customer..but i talk back is not listen
i using wireshare capture, traffic SCCP bypass Call manager and connected with Voice Gateway
Can you help me
Quycv@
06-27-2011 09:03 PM
Have you checked the network connection between your SCCP phone and the voice gateway?
06-28-2011 07:47 PM
thats right it might be a routing issue ( one way audio ) once the call is extablished it will be direct between the vocie gateway and th eIP phone
but not sure if the voice gateway is using IP to connect to the customer or ISDN ?
simply check the routing end to end between teh ip phone subbnet and the destination either vocie gateway or and other remote ip phone
06-29-2011 03:00 AM
Thanks your support
but i had troubleshoot it ok, I had enable Media Terminal Point request in gateway trunk SIP
