07-18-2018 07:47 AM - edited 03-19-2019 01:28 PM
Hi Team,
Can we have ICT trunk (Non Gatekeeper Controlled) between two CUCM Clusters running on different major version.
We have CUCM-9.1 running having ICT trunks with other CUCM Cluster. And we are planning to upgrade this CUCM from 9.1 to 11.5. Will our ICT trunk keep working after upgrade ?
Aniket
Solved! Go to Solution.
07-18-2018 08:42 AM
Yes, however the recommendation is to use SIP trunks for CUCM 8.6+ and only use ICT if you're using releases prior to 8.6
07-18-2018 08:42 AM
11-29-2018 04:46 PM
OK we have 10.5 PCCE and a 10.5 back office CM clusters w/Unity Connection connected with ICT. Calls begin in PCCE with a basic script that asks you to enter your parties extension. The end-users are on the 10.5 back-office. Calls route fine to the extension when entered. But when the call goes to voicemail it drops the call. I can call directly from the PCCE to back office and it goes just fine to voicemail. It's only when you use a script that it fails
Interesting item is that the phone is un-plugged on back office the call routes just fine to voicemail from the script
Any ideas?
