IM&P v11.5 Cluster Stuck In Failover State
Chris M
I noticed new users are not being assigned to IM&P servers.  When trying to assign them to a presence server in CUCM I received an error stating "Update failed. Cannot assign a user to a server that is not in a valid state".
On the IM&P servers there is an error stating "An automatic failover has been initiated due to the peer node being down" on the same day there was a network hardware failure in the core. In CUCM > System > Presence Redundancy Groups for IM&P it shows node 1 as "Running in Backup Mode" and node 2 as "Taking Over".  Both reasons state "Peer Down".
They appear to be stuck in this state, and I can't find a document on how to best manually force them back.  I assume it would be as simple as restarting some service(s) but I'm not sure which one(s).
Chris M
Thanks Hari Prasad for the reply.
I had contacted TAC with the tomcat logs.
After reviewing replication and finding no issues I was instructed to attempt to force HA failover in the CLI but this did not work as the devices were not in a working state.
What worked was going into CUCM > System > Presence Redundancy Groups, select the group and disable HA. Then I restarted both presence servers. When they came back the Tomcat services were running fine. Once all services were up, I enabled HA in CUCM and tested adding a user successfully. Users can also log in to Jabber.
Chris M
Update: Rebooted the publisher IM&P but Cisco Tomcat will not start now, despite "utils system start Cisco Tomcat". Creating a TAC case.
Hari Prasad
Hello Chris,
Could you please share outputs.
CUCM PUB>>
utils dbreplication runtimestate
Show network cluster
utils diagnose test.
Utils service list
Presence Node PUB->>
utils diagnose test
utils service list
Please rate helpful posts
Thanks, Hari Prasad
Chris M
