09-01-2014 02:25 PM - edited 03-19-2019 08:33 AM
Hi All,
I was trying to setup an signed ssl cert for my presence install but i broke something. Thus far i have only generated a sign request for the tomcat web services, and uploaded the root cert as well as the signed cert from the vender.
Now call manager does not see the services running in im and presence server. When i do a diag in IM and presence server, the following fail
09-03-2014 01:29 PM
If you look on CUCM, there are Tomcat-Trust certs....essentially copies of the certificate so that CUCM knows to trust it.
Chances are good that if you replaced the tomcat cert on the IM&P server you'll need to delete the existing Tomcat-Trust on the CUCM servers, and upload an exported copy of the TOMCAT cert into them as a tomcast-trust.
This is a real pain, but I've had to do it to get servers relinked before when a cert replacement breaks something.
06-05-2016 12:20 PM
Just Generate Self-signed from Cisco Unified OS Administration/Security on both server and wait 10 minutes and will work.
Cheers
09-08-2015 11:14 AM
I'm having the same problem. In an attempt to change the IM&P default domain I disabled HA on the Presence Group then disabled the requisite services on each member of the cluster then went to the Advanced Presence settings but the option was still grayed out. Now when I look in the system troubleshooter I see the message above (Could not determine the status of the Cisco IM and Presence Data Monitor service on the following nodes) in addition to errors resulting from the services I stopped. I have made sure no services are starting, stopping, or restarting and retried the tests with the same results.
We are in the process of installing certs for tomcat and cup-xmpp. So far tomcat is done and I was working on xmpp when I realized the default domain field was adding an invalid SAN to the CSR.
Any ideas?
