IM & Presence Installation Issue
I'm trying to install the IM & Presence version 10.5.(2) and getting the following error message after the installation.
" A Cisco DB may have encountered a known issue - If services are not starting please run 'utils service restart Service Manager'"
Do you have any idea how to fix that?
6 Replies 6
Manish Gogna
Hi Jefferson,
Is it the first node in the IM&P cluster?
Are the correct specs configured as per OVA guidelines below?
http://docwiki.cisco.com/wiki/Virtualization_for_Unified_CM_IM_and_Presence
Please ensure the NTP server is working correctly and reachable from IM&P server.
Manish
Hi Manish,
Thank you for your tip. I faced up the same db issue and the solution was to set up correctly the NTP.
asenapat
Hi Jeff,
I am having same issue and encountered same error when I am trying to login to IMP via CLI.
Please let me know what was the issue and how it got fixed.
neil wooloff
I am getting this message sometimes when access the cli.
checked and all services are started ok
ntp & dns all good
built using a good md5 checked ova also
Did you get a fix or indication of what is causing this?
Neil
this error message generally comes when server is unable to read its own database for some reason. if anything is wrong in database then services refuse to start. i suggest you to check your db replication for cups cluster.
I have a single cucm & single imp and repl was all good.
i did a clean shutdown and power on and all came up ok.
i also installed the vmtools.cop.sgn file but they still not register as installed, so think a clean buil may be in order.
Thanks for confirming what it does though.
Neil
