Important resource for Implementation of CUCM and UnityCn?
Vishal Bhardwaj
Hi Guys,
I just wanted to know if you can please suggest which is an important resource for Implementation? I know there are SRNDs, System and Admin guides but can someone please suggest where we can get detailed information on how to Implement CUCM and UnityCn with commands or menu options etc.?
If somebody can guide me in the right direct that'll be great?
skilambi
There is admin guides for both products
Look under each product you will see install and admin guides. That is the best place to start.
Srini
skilambi
Srini
Thanks Srini .. I will look into both .. they are huge .. anyways.. appreciate your quick reply as always.
You may also want to refer to the SBA guides which may also help (link may break)
http://www.cisco.com/en/US/docs/solutions/SBA/February2013/Cisco_SBA_COL_TelephonyUsingCiscoUCMDeploymentGuide-Feb2013.pdf
To get to all SBA guides use http://www.cisco.com/go/sba
Rgs
ashish
Response Signature
Thanks Ashish.. i have bookmarked the SBA Guides.. will be helpful for sure... thanks once again
