04-12-2013 06:27 AM
Hi Guys,
I just wanted to know if you can please suggest which is an important resource for Implementation? I know there are SRNDs, System and Admin guides but can someone please suggest where we can get detailed information on how to Implement CUCM and UnityCn with commands or menu options etc.?
If somebody can guide me in the right direct that'll be great?
Solved! Go to Solution.
04-12-2013 06:37 AM
There is admin guides for both products
Look under each product you will see install and admin guides. That is the best place to start.
Srini
04-12-2013 06:37 AM
Srini
04-12-2013 07:10 AM
Thanks Srini .. I will look into both .. they are huge .. anyways.. appreciate your quick reply as always.
04-12-2013 08:08 AM
You may also want to refer to the SBA guides which may also help (link may break)
To get to all SBA guides use http://www.cisco.com/go/sba
Rgs
ashish
04-12-2013 08:23 AM
Thanks Ashish.. i have bookmarked the SBA Guides.. will be helpful for sure... thanks once again
