02-06-2017 02:10 AM - edited 03-19-2019 12:05 PM
Dear All,
Is it possible to transfer incoming call on Phone A to Phone B by simply pressing single key on Phone A itself.
Here I do not want to receive the call & then transfer it. But I need to transfer the call to another extension while it is still ringing.
Please suggest if it can be done & how it can be done.
Thanks & Regards,
Vikrant S Patil.
Solved! Go to Solution.
02-06-2017 02:14 AM
Hi Vikrant,
You can configure Call forward all on Phone A, other than that you can redirect a call through iDivert to voice mail, but the existing CUCM design does not let you transfer a call in ringing state.
(Rate if it helps)
JB
02-06-2017 02:14 AM
Hi Vikrant,
(Rate if it helps)
JB
