Installation fails for CUCM subscriber 10.5: exceeds 3600 seconds limit
I am attempting to install a subscriber CUCM server on a brand new UCS C220 M3BE. The installation of the publisher went perfectly fine, when I am installing the subscriber, I get the following message:
The installation has encountered a unrecoverable internal error. For further assistance report the following information to your support provider.
Command "/opt/cisco/install/bin/pmNormalizeGeneric/etc/opt/cisco/install/component_install_cmd_list" has exceeded timed threshold of 3600 seconds
The system will now halt.
continuing will allow you to dump diagnostic information before halting.
I found the following: https://tools.cisco.com/bugsearch/bug/CSCti73841
But that is referencing an old bug. I am installing from the following ISO: Bootable_UCSInstall_UCOS_10.5.1.10000-7.sgn
Any ideas?
8 Replies 8
Aman Soi
Never came across this error.
Please check for the below info:
a.Is Subscriber added in Pub?
b. Is NTP syncronised on Pub ? you can check on PUB by running utils ntp status
regds,
aman
The failure occurs after networking validation between the new server and the publisher.
The subscriber is added and NTP is okay.
Not sure how OVA template change fixed the problem.
I had the same issue and problem was clock difference between ESXi hosts running Pub and Sub. Once I synced both ESXi hosts to NTP, Sub install went through fine.
I had this same problem and the solution was indicated by vladmcisco
Important to note - I was using the BE6K C200 option in the OVA selection.
I tried it a few more times and it failed the same way every time.
I picked a larger (10,000 users) OVA selection and everything installed without a problem.
Amit23
Level 4
Level 4
hello,
i am getting error when installing cucm 10.5.2.10000-5 on publisher:
Warm Regard's
Amit Sahrma
Time sync issue between VMHost & VM Instance during M1 migration
CSCur94973
Description
Symptom:
Upgrade times out with the error:
Command "/opt/cisco/install/bin/pmNormalizeGeneric /etc/opt/cisco/install/component_install_cmd_list" has exceeded timed threshold of 3600 seconds
Conditions:
Migration from 6.1(5)/7.x/8.x/9.x/10.0(1)/10.5(1) to 10.5(2)
Workaround:
Disable the VM's ntp sync with the ESXi host using the workaround mentioned in the below link:http://kb.vmware.com/selfservice/microsites/search.do?language=en_US&cmd=displayKC&externalId=1189
Alternate workaround would be to configure ESXi server & CUCM publisher to point to same NTP server.
Further Problem Description:
Due to the symptoms, we see upgrade failures.
https://tools.cisco.com/bugsearch/bug/CSCur94973
This worked for me.  I had a CUCM 11.0.1.21900-11 installation fail.  I followed procedure #2 on the VMware KB article & attempted the installation again.  Worked perfectly.  Thanks!
