01-08-2023 10:42 PM
Hi Everyone Good Day I need a help we are having a HP 479FNW printer along with Cisco ATA 191 which we are using for fax internal fax is working but whenever you send outside it shows busy and canceled. I've allowed same CSS which we use for outside call with prefix. is there any way to fix this?
Solved! Go to Solution.
01-09-2023 05:33 AM
A simple first step would be to pick a known good fax number and do some testing. I would first call it from a cellular phone as a control and make sure you get a fax tone. Then try to send to that number from the fax machine behind the ATA. If that fails, I would take a test set and plug in to the ATA and call the same number from the test set. If the call succeeds on the test set and you hear a fax tone, the issue is with the fax machine configuration/compatibility. If the call fails, the issue is with your CUCM (or whatever call agent you use), your dial plan, the PSTN, etc.
01-09-2023 08:38 PM
Thank you @mradell I've tested by my cellular phone call is working fine and internal fax is also working fine but when it comes to outside it shows. com error 252 or busy
01-08-2023 11:33 PM
I would recommend you do some troubleshooting first. Check the logs in CUCM and/or GW/CUBE.
Nobody will be able to help you, with what you have written in your question.
01-09-2023 05:33 AM
01-09-2023 08:35 PM
01-09-2023 08:38 PM
01-09-2023 10:46 PM
Why don't you just check the logs?! This is the first step in troubleshooting. This is your task as a technician and nobody can take it away from you.
As said, nobody will be able to help you without having insight to the logs. It is just guessing, what might be the problem and what might be one possible solution?
01-10-2023 01:37 AM
