01-20-2023 07:21 AM
I am planning to Upgrade my
CUCM and IM&P cluster to 12.5 SU6 and I need to some about compatibility between collaboration system
1-should CUC and CUCM Upgraded to the same version or is there compatibility materx between them
2-is expressway X12.5.1 compatible with 12.5 SU6
Solved! Go to Solution.
01-20-2023 07:29 AM
Refer below link, all recommended version are listed. Keep all your applications asper the CSR compatibility guide
01-20-2023 08:14 AM
Yes it is, but you'd be recommended to upgrade to one of the later X14.0 releases, or even X14.2 due to the many security defects.
01-20-2023 07:29 AM
01-21-2023 07:30 AM
I can go either with minimum or recommended version
01-21-2023 08:42 AM
Yes, but recommended would be recommended.
01-20-2023 08:14 AM
01-20-2023 09:57 AM
I would suggest to go with expressway 14.0.9 as 14.2.1 is buggy. 14.2.2 I haven’t tested in production.
01-21-2023 07:32 AM
Is 12.5 SU6 Support push notification for Android and Apple jabber
