Is ESX5.5 U3 compatible with CUCM 11.5
samtech
We have CUCM 11.5.1.13901-3 OVA (version 1) deployed on ESXi 5.5 host with Express patch 3.
I am now planning to apply ESXi 5.5 Patch 11 and trying to find if this will be compatible with CUCM or are there any known issues.
Thanks in advance!
10 Replies 10
Hi Jamie
Thanks for your inputs. I went through this article however, it is not clear if the update versions are also compatible.
  • Cisco Collaboration apps do not prescribe or proscribe individual ESXi patches and updates. Cisco recommendation is to apply the latest patches and updates recommended by VMware and your hardware vendor. The following links can be used to determine if an individual Maintenance Release or patch "can" or "should" be deployed:
java
if this helps, please rate
Do you mean to refer to the same article as you posted before?
Yes, that's from the same link I posted.
java
Could you please help me point where it says ESXi 5.5 patch 11 will or will not work with CUCM 11.5?
Hi Jamie
With reference to your comment below, please point the link.
Ratheesh Kumar
Hi there
CUCM virtualization document doesn't recommend the patch versions. As per the Virtualization guide,
Supported Versions of VMware vSphere ESXi= 5.0 U1, 5.1, 5.5, 6.0, 6.5
CUCM 11.5.JPGhttps://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/virtualization/virtualization-cisco-unified-communications-manager.html
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
Hi Rath
Thanks for your inputs. Does that mean the updates should be compatible with these versions?
Hi there
As far as I know, as long as the major version of Esxi is mentioned, you are good to go. But for a double confirmation, you could open up a ticket with Cisco PDI. Here is the link for that
https://cisco.com/go/pdi
Hope this helps!
Cheers
Rath!
