Is it possible to connect SIP Trunk (ITSP) to Layer 3 switch
clynefury
Hi Guys,
Just want to ask if it is possible to connect SIP Trunk (ITSP) to Layer 3 switch rather than cube?
Thanks.
Not as a SIP device. If you connect it with a L3 switch it would just be for the connection, you still have to use something else to facilitate the SIP part of the connection.
Response Signature
Hi Roger,
This is our network diagram. We will have a virtual voice gateway.
I believe that would be a feasible setup, although I've not myself done a similar deployment. All SIP ITSP services that I've been part of has always been a point to point connections type.
Response Signature
Thank you Roger for your help :) much appreciated.
