Is there an updated way to add speed dials using BAT
Scuromano
I'm trying to update speed dials on 8845 phones, that is, to add the same speed dial number to the 4th line instance on the phones.  There are 2 Lines and 4 Speed dials on each phone (so this would be the second speed dial).  This is for CUCM 14.x.  The procedure I've found so far is 13 years old and I can't get it to work in my lab environment.  Either the procedure is wrong, I'm doing something wrong, or the procedure is not relevant to the newer versions.   Any suggestions?
This is one link:  Bulk Change Of Speed Dial - Cisco Community
This is another:  Configuring Speed Dial using Bulk Administration Tool (BAT)
Yes, that did work for me.  Was able to add the Phone Button Template and add the Speed Dial number to the correct line.  Thanks.
