Is there any way to restore NM-CUE data into AIM2-CUE?
jjia
Level 2
Level 2
The customer ordered AIM2-CUE to replace current NM-CUE module to support CUE v7.1 or later. I just wondering if it is possible to use NM-CUE data backup to be restored to AIM2-CUE module?
NM-CUE has 8 voice mail ports; while the AIM2-CUE has only 6 voicemail ports.
JJ
clileikis
Level 7
Level 7
Hi all,
Can anyone confirm this?  Particularly if we're using the "***" boot helper method for backup and restore from a NM-CUE to an AIM2-CUE.
Thanks!
Chris
