issue with voicemail
pranav desidi
Hi All , we have configured voicemail for our reception phone and recorded a personal greeting , everything is working fine but when users call and call is not answered first Cisco default Voicemail is heard then our recorded greeting. i have checked all the configuration in call handlers and everything seems to fine . thanks in advance..
6 Replies 6
Deepak Rawat
Make sure that on the required Call Handler >> Edit >> Greetings >> Standard >> Callers Hear is set to My Personal Recording
Deepak
Hi Deepak ,
As checked callers hears is set to My personal recording.
we are able to hear recorded message but before that Cisco default VM is playing.
Run Port Status Monitor and check what is the exact call flow once the call comes into Unity Connection that is playing the DEfault VM before your personal recording. PSM can be downloaded from below link
http://ciscounitytools.com/Applications/CxN/PortStatusMonitorCUC7x/PortStatusMonitorCUC7x.html
Deepak
Hi Deepak
called number 8200
attached report of Run Port Status Monitor
Call into CUC is coming for the number 8680 whereas the called number is 8200. For what extension have you created the CH in CUC.
Deepak
extension 8200 is pointed to CTI RP 8680 and in unity we have mentioned alternate extension  as 8680.
