Issues up grading Ip phone
I have tried everything I know and I'm missing something.  Still unable to get phones firmware to up load. I am able to get the phone to at least take part of the configure. Since I have to use the password to get into the phone. Only thing let is to have it display. any great wisdom. I have attached a few documents to show the firmware is in the TFTP server and the register global. Would to get this behind me and learn how to make this process quicker....
Thank you in advance for any advice....
From a working Environment.
CME running on ISR4k
tftp-server bootflash:kern2.78xx.12-7-1-0001-393.sbn
tftp-server bootflash:kern78xx.12-7-1-0001-393.sbn
tftp-server bootflash:rootfs2.78xx.12-7-1-0001-393.sbn
tftp-server bootflash:rootfs78xx.12-7-1-0001-393.sbn
tftp-server bootflash:sboot2.78xx.12-7-1-0001-393.sbn
tftp-server bootflash:sboot78xx.12-7-1-0001-393.sbn
tftp-server bootflash:sip78xx.12-7-1-0001-393.loads
tftp-server bootflash:boot1288xx.BE-01-007.sbn
tftp-server bootflash:fbi88xx.BE-01-012.sbn
tftp-server bootflash:kern88xx.12-7-1-0001-393.sbn
tftp-server bootflash:kern288xx.12-7-1-0001-393.sbn
tftp-server bootflash:kern388xx.12-7-1-0001-393.sbn
tftp-server bootflash:m0patch288xx.BE-01-001.sbn
tftp-server bootflash:preloader88xx.BE-01-002.sbn
tftp-server bootflash:rootfs88xx.12-7-1-0001-393.sbn
tftp-server bootflash:rootfs288xx.12-7-1-0001-393.sbn
tftp-server bootflash:rootfs388xx.12-7-1-0001-393.sbn
tftp-server bootflash:sb288xx.BE-01-026.sbn
tftp-server bootflash:sb2288xx.BE-01-013.sbn
tftp-server bootflash:sb2388xx.BE-01-027.sbn
tftp-server bootflash:sip88xx.12-7-1-0001-393.loads
tftp-server bootflash:ssb288xx.BE-01-007.sbn
tftp-server bootflash:vc488xx.12-7-1-0001-393.sbn
voice register global
 mode cme
 source-address X.X.X.X port 5060
 timeouts interdigit 5
 max-dn 100
 max-pool 100
 load 7841 sip78xx.12-8-1-0001-455
 load 8841 sip88xx.12-7-1-0001-393
 load 8851 sip88xx.12-7-1-0001-393
 olsontimezone Asia/Muscat version 2018e
 timezone 34
 date-format D/M/Y
 create profile sync 1506540522068233
 auto-register
Response Signature
No this is not a working environment, it is a testing environment.  I am trying to learn to set them up, so I can then take them to another router that is in a working environment and deploy them there.
Thanks again for taking the time to help...
I mean the above configuration which i shared is from a working customer site. Try the above.
Also  make sure that the files are in the right folders.
Response Signature
Ok making some progress, at least now. When I go into Phone information I  see the upgrade failed and the old firmware is still there but when I go to show details it has the current firmware visible and above it says inactive cmterm-88xx-14-0-1-0101-145
