LED status on MCS7835
mcdonovan
Hi, We have site that removed one of two power supplies from 7835 (model number: MCS7835H2-K9-CMA2) running CUCM 7.1.3 after it failed.  The LED status now appears normal.  My question is, should the LED indicate any type of alarm showing the power is not in a redundant state?
Aaron Harrison
If you have a PSU and it doesn't receive power or is faulty, then it's a fault.
If you don't have a secondary PSU, then it's not a fault as nothing is 'broken' - you may simply have not purchased that extra resilience.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron Harrison
Aaron
Makes perfect sense.  Thanks!
